My Granddaughter's 2011 Kia Soul has a starting problem related to battery and/or starter and/or charging system.
The car has started reliably for 7 years and 115,000 miles. Very dependable,..... until about two weeks ago. Now it starts about half the time.
A new battery was installed last June by Advanced Auto Parts in Cabot, AR. Still under warranty. The car is now in Newnan, GA.
Here are the problems:
-- Often it cranks over slowly,.. too slowly to actually start. On the second or third attempt, it just stops turning over and degrades to a rapidly clicking solenoid.
-- Sometimes it just does one click,... but sometimes it'll start normally a minute after that.
-- Sometimes it starts as if there were no issues at all. Intermittently it works fine. Very frustrating.
-- Within ten minutes or so of shutting it off, it will start up okay most of the time.
When the motor is running, the voltage at the battery terminals is 14.5V. When cranking the starter after it has been running for a while, the voltage at the terminals is about 10V. With a cable disconnected and the motor not running, the "at rest" battery voltage a minute after the motor was shut off is about 12.2V.
A reputable repair shop (Crossroads Automotive in Newnan, GA) tested the battery and said it was bad. Only 36 CCA. The Advanced Auto Parts store across the street tested the battery and said it was fine, so they won't replace it.
When the car won't start, using jumper cables (or one of the little battery-powered jump starters) makes it start rapidly and all the problems mentioned above go away.
When I disconnect the ground cable from the battery, then insert a multimeter between the terminal and the cable, there is amperage of about .25A for a couple seconds, then it decreases to around .01A and stays there. Does this qualify as a parasitic drain?
It seems to me the battery is dying and Advanced Auto Parts won't replace it because their tester "says" the battery is good.
