I just put in a set of DRLs, I think it looks pretty good!
They look great , but with summer temps of 105-120 where you live , watch your temp gauge closely as you have restricted 50% of your air flow inlets for your engine cooling system . Also lessening the amount of air passing through your condenser will cause your a/c to blow air that is not as cold as it could be .I just put in a set of DRLs, I think it looks pretty good!
Doesn't that whole bottom part let air through??They look great , but with summer temps of 105-120 where you live , watch your temp gauge closely as you have restricted 50% of your air flow inlets for your engine cooling system . Also lessening the amount of air passing through your condenser will cause your a/c to blow air that is not as cold as it could be .I just put in a set of DRLs, I think it looks pretty good!
Go look at it. You will see that half of it is closed off.Doesn't that whole bottom part let air through??
yeah but covering two of those slits doesnt cut the airflow in halfGo look at it. You will see that half of it is closed off.
Was it hard to install? I'm not too experienced with electrical work, are the directions pretty straight forward?I just put in a set of DRLs, I think it looks pretty good!
