1 - 3 of 3 Posts
I want to do permanent install on a dash cam, but I'm not sure how to remove the A pillar trim on the 2020 to run power. Anybody have tips?
You don't need to pull the A pillar trim, pull down the door shut gasket there is enough wiggle room to tuck the wire in at the top where the trim meets the headliner. Then run the wire down the gap behind the gasket, put the gasket back in place and you are good to go. Hope this explanation makes sense.
Pat.
This is for the second gen car, maybe you can find one for your model maybe it is similar.
I don't recall replacing any clips. Seems like I just pried it off then popped it back in when done. I did not use that tool, just a plastic pry bar. Also removed the panel on the left end of the dash with a warning label on it, to hide my wire. Just pried it off carefully.
Kia Soul: Front Pillar Trim Replacement - Interior Trim - Body (Interior and Exterior)
1 - 3 of 3 Posts
