Greetings! As many of you know, the type "A" headlights use an H19 halogen bulb. This is a modified H4, from what I can tell. Have ANY of you found and or installed a LED headlight bulb for the "A" headlamp? I did find a guy who sells a kit on ebay, but I don't want to spend $150.00, unless there is no other option. Amazon sells a 9003 LED that the "seller say's" will fit. Ok...but just because it fit's, doesn't mean it's actually "Correct" for the lens/reflector design. To date I'm loving the car but don't like the yellowish, semi-dim factory headlights! Any help will be very much appreciated!
