1 - 6 of 6 Posts
My 2020 GT Line Turbo Nav is not working when you type an address in it comes back no results or weak signal or software needs updating
I tried typing my home address in while sitting in my driveway same result couldn't find it, sometime if you do a search you get a result but its hit and miss.
The dealer has had my car from three days no results they are contacting the factory on the next business day.Any other 2020 soul owners with the same problem
and has been repaired please post what it took to repair this problem thanks
Had same issue in my 2019 and they reflashed my head unit and it started to work. Not the map card but the actual head unit. I noticed it before I left the dealership the day I purchased it and they got right on it.
I have same prob on 2020 EX, it no longer can decipher & map addresses input for navigation. So its a dealer issue?
Yup. Just started with the same problem when trying to enter the address. However, I discovered that it DOES work if I use the voice recognition system. Has anyone found a solution for this?
I can't get android auto to work after the update. Also, it don't seem to understand what I'm saying half the time. It worked perfectly before the April update.
1 - 6 of 6 Posts
