Hi all, My wife drives a 2019 Kia Soul that we purchased used with just over 8k miles on it. We have had the car about 2 years now and the car has 77k miles on it now. Just this past Sunday I noticed the car ticking. I immediately pulled over and checked the oil level to find that there was little to no oil showing. Took it across the street to Jiffy Lube, had an oil change done and the tech confirmed what I feared: 1) almost no oil in car 2) sounded like a bearing/rod problem (likely need a rebuild). Drove the car home (about 13 miles) and sure enough, flashing check engine light and limp mode.
My major issue here is my wife has been meticulous about changing the oil in this car (every 3500 or so miles) and there was no low oil indicator light on in the car, ever, even when the engine started ticking.
The car was previously a rental in FL. I suspect that being first sold by Kia as a rental, that it has a different software load than a "normal" 2019 Soul. (For instance, every time we start the car we have to tap the button on the info panel that we understand to use the car safely etc.). Is it possible this is why the oil indicator light never came on? Not having any oil showing and no indicator light and my wife having just completed a trip from NC to GA and back, should we suspect that that the previous oil change place didn't put oil in or more likely that the car burned the oil (no smoke or leaks) as I have read in other threads?
Would love to hear your thoughts!
