21 - 22 of 22 Posts
Good info on the harness. I was recently putting a stereo in a 2015 Sportage and had the same issue with a Metra harness. They only put the basic wires in the harness. They need to add wiring for cameras, mics, USB etc. One way around this is to buy two harnesses and grab the wires as needed out of the second harness. I think Amazon had pin removal tools.
I found the wiring pin out in case anyone else comes looking for it. I was able to wire in the OEM backup camera. I just connected to power for the camera to the ACC wire (camera needs 12v, not 3.3v). For the signal wires I used an old RCA plug and spliced it in.
Connector A
1 Rear left speaker (+)
2 Rear left speaker (-)
3 USB Ground
4 USB Data (+)
5 USB Data (-)
6 USB VCC Illumination (+)
7 Camera video
8 -
9 -
10 AUX Audio right input
11 AUX Detect
12 Steering wheel remote controller
13 Front left speaker (+)
14 Front left speaker (-)
15 Front right speaker (-)
16 Front right speaker (+)
17 -
18 -
19 -
20 Camera ground
21 Camera VIN ground –
22 -
23 -
24 AUX Left input
25 AUX Ground
26 Steering wheel remote controller ground
27 Rear right speaker (-)
28 Rear right speaker (+)
29 -
30 -
31 -
32 -
33 Camera VIN shield
34 -
35 -
36 -
37 -
38 -
Connector B
1
2 MIC (+)
3
4 Detect
5 Remote antenna
6 Illumination (+)
7 Multmedia-CAN (High)
8 -
9 -
10 Battery (+)
11 Battery (+)
12 Ground
13 Ground
14 MIC (Ground)
15 MIC (-)
16 Ground
17 Neutral_Gear switch
18 -
19 Illumination (-)
20 Multmedia-CAN (Low)
21 -
22 ACC
23 -
24 -
25 Reverse signal
26 Door open
27 Door unlock
28 Parking brake
29 "P" Position
30 Auto light
31 TCU Type (M/T GND)
32 -
33 IGN1
34 -
35 -
36 -
37 -
38 -
I am installing an Alpine iXL-W650 into my son's 2019 KIA Soul Base model and am trying to use the OE Microphone. Could you do me a favor and associate the pin numbers to the plug or adapter? I do not want to splice into the wrong wires.
Also the 70-7307 is supposed to retain USB and AUX port.
Your help would be greatly appreciated!
2019 Kia Soul Base
2016 Kia Soul+
21 - 22 of 22 Posts
