Likely you just need a new crankshaft position sensor. Buy a Kia part.
You can also search the forum for “crankshaft position sensor” and find others having similar issues and solutions.
It does set a code but it doesn’t store it for some reason. The next time it happens, don’t key off the car. Plug in your scanner and it should show a code. Once you take the key out then turn it back on the code will be gone.
