1 - 3 of 3 Posts
I have a 2016 kia soul with 99,000 miles it recently started burning alot of oil. Will my powertrain warranty cover repairs? Also has anyone else had this issue?
If you are the original owner the powertrain will cover it. You need to make an appointment at the dealer ASAP. They will start an oil consumption test, basically return after 1k miles to see how much it is using. If it's over 1qt they will need your car overnight to perform compression tests and inject chemicals to clean the carbon off the rings. If the carbon cleaning doesn't work you will likely be eligible for a rebuild. Kias servers have been down for 10 days now so I'm just going off memory what the process is.
1 - 3 of 3 Posts
