1 - 10 of 10 Posts
Does anyone have a procedure or tutorial on door panel removal for the 2014 Soul? What about the dash speakers?
I talked to the dealer and they said (with little confidence; they weren't very sure) there's a screw behind where you pull the door open, and where you grip the door to shut it.
After those two screws are removed, you can pry from the bottom (there's a notch on the steel to put a tool.)
Beyond that, I have no knowledge.
As for the dash speakers, they told me "Pry them off with a screwdriver...Good luck"
I'm not having that warm/fuzzy feeling to move forward...Could anyone help me out?
Thanks in advanced!
Thanks in advanced!
Hey Scharf,
First & foremost, DO NOT pry any visable areas on the Soul with a screwdriver or metal object. They will scratch very easily. I would invest in some plastic pry tools. They aren't expensive. I got a pack of 5 various sizes for about $6.
Having said that, here's a video of the center speaker removal by a woman using a screwdriver (to each is own):
https://www.youtube.com/watch?v=Ssu2FQFMMfk
These images might help with the door panel removal. Best of luck.
Short of fixing a problem, why are people taking off gen 2 door panels?
Because they can......
I am going to be putting new speakers in soon. so if I am the first I will be doing a how to on it. like i did with the underglow. and get plastic trim tools... like above you can get a set for 6$. or a nice set for 20.
1 - 10 of 10 Posts
