My wife’s daily driver. Starting about 6 months ago, every now and then, once a week at most, it at like it doesn’t want to start. Will try to turn over but acts like it’s not getting gas. If I lay on the gas pedal for a few secoyit starts right up, but then runs like crap with limited pot. Otherwise, it starts and runs well. Even when it acts up, I can let it sit for a minute, restart it, and it runs fine. Like I said happens 2-3 times a month. I run Techron through the tank, and have changed the plugs. No check engine codes. Any ideas? Thanks
Good question. I’m not %100 sure I have paid attention to that. I want to say that nothing is abnormal with the tachometer. But I will verify next time it acts up
The reason I ask is because if the crankshaft position sensor is going bad, it can have some of the symptoms you’re having, (intermittent extended crank and running like poo), and also the tach will stay at zero. If that’s the case and yours is bad, use a genuine Kia part from the dealer if you can, or at least a high quality aftermarket one.
Had the same issue with my 2014 2.0. Was doing the same thing yours was doing but only when the motor was warm and I was going to restart. It didn't throw any codes until it got really bad. It was the Crankshaft Position Sensor.
Ok so replaced the CPS. No non-starting issues yet. But still have the running rough/loss of power/slow acceleration issue. I was hoping they were related…
This is a good thread on how to help reduce oil consumption. Take a look at the “For serious oil loss” section and search the internet and YouTube and even here on how to do a piston soak.
Depending on how bad your piston rings are clogged with carbon, a “piston soak” can sometimes help free them and reduce or even stop consumption. If your cat is bad, you’ll want to address the oil burning or a new cat will fail too.
Do you have the 1.6L or 2.0L? There was a cat recall for the 1.6L and there’s a couple other recalls for both engines. Did you have them completed at your dealer?
How to prevent oil and power loss in a Kia Soul GDI engine compiled and written by westslope with valuable input from GeekOnTheHill, GeoSoul and SportsterDoc Gasoline Direct Injection (GDI) engines can be more efficient than multiport injection (MPI) engines but require more pro-active...
That is weird. I would've thought that a plugged cat would be plugged all the time, not just occasionally. Like every time you need the power it wouldn't be able to breath like it should so it should never run normal.
I'm having the same issue with my 2016 with 130k on it. At first after reading through some posts I figured it was the crank position sensor but now I see it maybe more than that.
I also burn a quart every 1500 to 2500 miles, just started using the synthetic in the last 20k.
And as soon as it got cold the mileage went way down, from 27-28 to right now reading 21mpg.
Is it true that a new cat is half the price of a new engine?
jimmy
Related Threads
422.6K posts
50.4K members
Since 2008
