Hi all! New to the forum. Recently my daughter blew a head gasket on her Kia. I have done a little work on head gaskets before. I am trying to find what is the compression test with it being cold. Meaning, the Kia only turns over but won't start. I have a full piston/rings replacement, new gasket, checked intake and exhaust camshaft solenoids, sensors, timing chain, tensioner, checked for spark, checked for good fuel pump to engine AND a compression test but I am not sure if the spec is the same for an engine that is only cranking and not running. Any help is greatly appreciated!
currently I am only getting around 40-60 psi on all four cylinders
