Hi all! I started having an issue about a year ago where my 2013 Kia Soul (!) would stutter at the lower end of a gear when accelerating or cruise control. Example, the 6th gear engages around 40mph; if I slowly accelerated at around 41-42mph, then the car would stutter and RPMs would dip for about 2-3 seconds before the car would either shift down to 5th gear or raise the RPMs in 6th to get power. I had the battery and alternator both replaced about a month ago, which helped the issue, but did not fix it. Additionally, I started the car up yesterday and it took about 10 seconds to actually crank up, and once it did, the tachometer (RPM gauge) stayed at zero after ignition; driving it around the parking lot revealed that the car wouldn't downshift at all and only shift up into 4th gear. I had to put it in neutral to get the gear to go back down. At no point has a check engine light or battery light turned on.
Any advice or ideas would be helpful as I've already spent a ton in diagnostics and repairs.
