1 - 2 of 2 Posts
Hi,
I want to install a dash cam to my 2013 Kia soul+, which fuse should I tap off ?
This is the dash cam i want to install: Amazon.com: Hdvr-150 Car Accident Camera Video Recorder Dvr: Car Electronics
it takes 12v, 0.2amp.
i was thinking about using the 20A lighter fuse, but I couldn't find a "add a circuit" kit for 20amp fuses. The one from Amazon is for upto 10amps. Also, what kind of fuse should I get, there seems to be a lot of different kinds: mini, ato, atm, etc...
Also, what should I use for ground ?
thanks,
The regular add a fuse kit is plenty powerful enough. You don't need or want to have a fuse rated at 100x the load. That rating is for the added fuse. When you put a fuse in the added slot, make sure to use as close to the rated load as you can. I'd put a half amp fuse in that slot.
1 - 2 of 2 Posts
