Had the whop whop whop noise from front axles…. Replaced both axles and bearings. Still had problem and a new problem of driver side vibration while accelerating and only when it hit 2600-2900 RPM…. Immediately Replaced both axles again and solved the whop whop whop noise (must have had a bad axle that was NEW from Autozone because the second time I replaced with NAPA). However, problem solved of whop whop whop noise, but now I still have the vibration noise from driver side and now it also has a vibration sound when starting off from a stop to about 1500 RPM and then again 2600-2900 RPM…. Hard to believe i have two bad axles in a row from two different companies.
Any ideas are most appreciated. Thanks!
