I am having strange electrical issues with a number of systems. Nothing related to the engine running. However, here is a list of what is happening
What I've tried:
I'm not sure what to do. Any ideas where to start? Thanks.
- Push on the brake, the radio dims. Seems to be going into "Night Mode".
- If the lights are ON, then push on the brake, the dash or cluster light fails. It goes completely black while the brake is pressed.
- If cruise is on, I signal left, the cruise let's go. The cruise stays on if I signal right.
- If the headlights are on, curise will not set
What I've tried:
- Checked all fuses.
- Checked all the grounding points I could find.
- Ground off the paint under the main ground wire (found that in another thread)
- Checked OBDII. Nothing
