There should be no difference if you size the tires correctly.
[2 * width * profile% + rim dia] should be identical with whatever sets of rims/tires you put on a car.
Any difference between the old and new overall diameter will translate as a change in final gearing ratio and a change in performance. Smaller will equal faster acceleration lower top end, larger the opposite.
IIRC. Sold tires for a number of years, but that was some time ago.
Actually with the 18" rims the speedo probably reads 4% slower than with the 16" rims
Rim (in) Width (mm) Sidewall % Sidewall (mm) Sidewall (in) Total Dia (in) % difference
15" tires, P195/65 R15 15 195 65 126.75 4.99015748 24.98031496 0.0%
16" tires, P205/55 R16 16 205 55 112.75 4.438976378 24.87795276 -0.4%
18" tires, P225/45 R18 18 225 45 101.25 3.986220472 25.97244094 4.0%
http://www.tiresizecalculator.info/
How about 20" Rims and these?
http://www.tirerack.com/tires/Compa...e&pagelen=20&pagenum=1&pagemark=1&RunFlat=All
